I loacted a 1986 DT60 donor engine (frozen power head) with a sound lower unit from a reputable Suzuki dealer in Shelton Wa. Picked up the motor, took it home and I was able to drop the lower unit with no problems.
Mine is a 1983 DT50, the dealer assured me it would fit my power head, the spline count matches, the cut on DT60 is a bit longer than the DT50 (I would not think this a problem) but other than that it appears to be correct.
Here is my problem, when I attempt to install the DT60 unit on to the DT50, as the drive shaft slips into the power head it stops, I am not able to get close enough to start any of the bolts with the exception of the long bolt that is directly above the prop thus leaving a gap of about 2 inches. This is verified by the grease trail (using plenty of grease) left on the spline, showing approximately 1 1/2 inch insertion. And yes I am rotating the prop shaft as I am installing the driveshaft.
I don't want to force the shaft , I have in the past rebuilt the water pump and it slipped back into place with no problems (original unit). Could the problem that this shaft is from a different motor ? Or I am overlooking something,
Any suggestions?
Any suggestions?
