Apologies, but I've searched quite a bit for existing solutions, and can't find troubleshooting advice.
Have run the motor 5 or 6 times this year with no problem. Last time out, seemed a little rough after starting but once underway no problem.
One week later, I have to fiddle with the choke to keep the engine running, and have to keep the throttle at 1/4 or more. Below this will stall regardless of the choke setting.
1. thought it might be the gas so I made sure the tank air intake was open, and discarded my old gas, and refilled with octane 89 (medium grade from Exxon). Ran the engine for 10 mins, but still same problems.
2. checked the plugs. They are slightly "wet" with a black oily mix, but otherwise clean, and look like new.
Wondering if these symptoms might point to:
1. bad plugs or wires or other electrical? At higher RPM is there less need for a spark based on previous ignition cycle???
2. clogged carb or oil injectors. If so, any advice on using an additive to clean, or should I take the motor in for a general cleaning / tune up, or are there simple steps a weekend warrior can follow.
Anything else you think I should check before taking the engine in?
Thanks in advance.
Thanks in advance.
