had fuel problems last year, with help from rodbolt and others was able to fix. problems are back again, my tank is the problem. i have installed a new tank and changed all filters(vst was clean ) but fuel psi. reg. filter was plugged almost solid. sent injectors to be cleaned & flow tested (inject. wrhs. in hemmingway s.c.) just reinstalled inj. & hooked up new tank,started motor & idle was higer (after warm-up) 1100 and getting some sheen (oil/gas) in water. did not get out for test run , wind blowing 30 plus. any ideas why it would do this? thanks. motor is 1997
