ReedvilleVaBoater
- Aug 3, 2009
- 20
Engine has started misfiring and running rough. I pulled the plugs and they were really gummed up. I had just replaced them back in April. I went ahead and replaced them again and checked for spark and everything looked good. But it is still not running right. So I think it is either a fuel issue or a compression issue. The fuel filter was changed in april as well.
At WOT it will only turn about 3200rpm or about 9 knots. After about 20 minutes of running like that it will start to hit on all cylinders and it will speed on up. It seems to stay that way until you stop and let the engine cool.
Any ideas? Sounds to me like low compression until it heats up and the piston expands. I haven't had a chance to check the compression yet. But last year it was good.
