Re: Digital Gauge to Analog Conversion
Im trying to do the same with a 2000 250hp outboard. I have a 7000 rpm analog tach working by using the dark green wire off the key switch, connected to the sending unit terminal on the tach. The tach will also have to be ajusted to suit your motor (# of cylinders). I havn't been able to get a temperature gauge or the tilt gauge to work though. The gauges for those might be yamaha only / not generic like I have been trying.
