I have a 05 4 stroke yam 25hp it wasnt idleing good and found out it has 60lbs each cylinder.. used a clearer to clear out carbon buildup brought compression to 100lbs each.. next day only had 50 each... no scoring or anything on cylinder walls and rings dont seem to be stuck.. valve is working.. head gasket seems to be ok but i am replacing just incase.. what else could it be if not head gasket? what am i looking at paying here? thanks for any help..
