waltdiggity
- Jul 25, 2009
- 8
i have replaced pump on remote tank, still wont fill tank on motor. does work off emergency switch. oil sender is working it sounds warning horn. i continuity tested all wires on tank harness from motor to tank. i even swapped cdi's.(twins) i also replaced trim sender because it was stuck. im running out of ideas. Any suggestions?
