Symptoms of the problem: When I initially turn on the ignition I get 3 short beeps followed by 1 long from the system monitor, and then this sequence starts all over again. I do get the initial tone from the monitor and then the error codes start. I can start the engine, but the beeping continues. When I engage the motor the power is restricted by the "slow motion" mode. I get a good solid stream of water out of the water outlet, so I don't think it is water circulation issue. I too checked the oil and it appears to be good as well. I would really appreciate the help of anyone who might have a suggestion. I believe that the code (from other posts) appears to be related to the IAC sensor, but all wiring to the sensor looks good. It too appears (as least by way of resistance check ) that the sensor is open. Anyone have any ideas?
Thanks in advance for your help.
