Hi Guys, I have a 1983 DT 25 which is running rich and lacks power under load, I have cleaned the carb, replaced the float, needle and seat, checked the fuel pump for leak into the crankcase, replaced plugs, have about 120 psi compression and spark at idle and under load. continues to blacken the plugs. don't know what to check next and need some help
Thanks for any help
Richard
Thanks for any help
Richard
