simplystressed
- Mar 16, 2009
- 176
Hi all,
I have a DF15 and since changing the oil there has been a slight leak at the oil drain screw on the engine block. I ordered another screw gasket today and installed and noticed there is still a leak
Seems the copper gasket isn't making a tight enough seal (not sure why its copper) and I don't want to overtorque.
Has anyone else came across this? Should I use RTV or Teflon tape on the screw as well to stop the small leak? Just wondering some suggestions.
