Hey Guys,
Last season i had an issue with the motor not being able to turn over 3200 rpms....it would bog down etc...turned out to be a clogged carb...the motor runs very well now both at idle and full throttle the only problem is that it max's out at 4200 rpms. She runs great and is up on plane doing about 30mph at 4200 rpms, never bogs down, sputters or anything...i had noticed that there is a cam and a cam follower on this engine. the follower is worn out and when the boat is in neutral, the follower does not even touch the cam. infact, it sits about 1/8" away from the cam. Is it possible that this could be causing the motor not to turn 5500rpms at full throttle. SOmeone else had mentioned compression problems to me but i thought i would have noticed teh motor running funny (could very well be wrong though)
