quietstorm
- Nov 13, 2004
- 20
Hey guys,
I?ve cut a few cables to make up my own interface connector to connect my new 2010 DF90 to my Lowrance sounder ? I just want to double check what the pinout or wiring diagram is for the 4 pin square diagnostics plug on the engine (near the ecu) that i?m going to plug the cable into. Just want to double check that i?ve wired the nmea plugs correctly.
Would be great to confirm what each wire/pin in the square engine dianotics plugs is for i.e. orange is data, red is power etc.
Thanks,
Storm
Thanks,
Storm
