I have a 90 Suzuki pu40 that doesn't have a steady stream of water coming out the pee hole at idle. It's more of a dribble. When revved up it does better. I justed replaced the impeller, could there be a piece of the old one stuck in the waterjackets or tubes? Does anyone know the best way to check this or flush it out? Also, as I blow high air pressure in the pee hole and block up the water tube at the other end, I can hear air blowing somewhere in the casing. Is this normal?
