Is this valve supposed to be open or closed when under normal operation??
A Asainz320 Petty Officer 2nd Class Joined Sep 27, 2006 Messages 137 May 26, 2010 #1 Is this valve supposed to be open or closed when under normal operation?? Attachments Manual Enrichment Valve.jpg 17.5 KB · Views: 0
R rodbolt Supreme Mariner Joined Sep 1, 2003 Messages 20,066 May 26, 2010 #2 Re: Manual Enrichment Valve 96 225hp Yamaha. closed
A Asainz320 Petty Officer 2nd Class Joined Sep 27, 2006 Messages 137 May 26, 2010 #3 Re: Manual Enrichment Valve 96 225hp Yamaha. Thanks rodbolt!! Whats the use for this valve?
R rodbolt Supreme Mariner Joined Sep 1, 2003 Messages 20,066 May 26, 2010 #4 Re: Manual Enrichment Valve 96 225hp Yamaha. in case the automatic system fails or the battery is dead and your manually starting it you can manually enrich the fuel for cold starting.
A Asainz320 Petty Officer 2nd Class Joined Sep 27, 2006 Messages 137 May 26, 2010 #5 Re: Manual Enrichment Valve 96 225hp Yamaha. ohh ok, good to know. Thanks again man you're the best!
