Trying to do a impeller for a friend on his 20hp its a 20LF on the tag, now how to I disconnect the shift rod? I see just above the lower housing there is a double nut on the shift rod, do you undo it there? There is also a small rod that goes from there to what looks like the tilt lock for when put into reverse.
