PEARSON26VT
- May 8, 2010
- 1
My brand new 2010 DF9.9 Suzuki motor does not always spray water out the pilot water hole. Some times it has a strong flow and other times it has little or no flow. The manual says that it should have flow as soon as it starts.
When it does have flow the water is so hot, that you can't hold your hand under the stream. Some times a vapor seams to come out the hole.
Should the water flow only when it reaches a certain temperature?
The motor appears to emit alot of exhaust fumes.
