Ruggybuggy
- Sep 18, 2009
- 114
The motor is a 2004 Yamaha 40tlrc that has about 15 hours of use. If you listen carefully you can hear a rattle noise as soon as it put into gear (forward or reverse) and as soon as you get off idle the rattle stops. It doesn't rattle in neutral. Noise seems to be coming in the area between the lower unit and power head. I took the lower unit off and found nothing unusual. Lower unit oil is clean and nothing on the magnet. I inspected the water pump housing and everything looks fine. I put a coating of grease on the input shaft and put it back together and still have the noise. It's not the shifting rod rattling because if I grab it while running the noise is still there. The power head runs fine with no overheating issues.
I'm starting to believe this is a normal noise. Can anyone verify. I just install the motor on the boat and haven't used it yet. Just want to make sure this is nothing to worry about. Thanks for any help in advance.
Dave
http://s392.photobucket.com/albums/pp10/Ruggybuggy/?action=view¤t=SDV_0017.flv
Dave
