Re: temperature and pressure gauge yamaha 150 hpdi location?
i will have to check on the gauge (brand). probably not yamaha.
it is a salt water engine, so i will have to rethink/see if there a good reason to do this .
i don't need to remove the pressure tap only to find i can't get the fitting to screw in because it stripped out. that would not be worth the trouble.
i mounted a jackplate and thought a temp gauge and later on a pressure gauge would be nice to have/moniter.
