Last year I bought a used Suzuki DT9.9c outboard to use on my 12' aluminum boat. After a thorough cleaning of the carb, it started right up and seemed to run strong. I bought a used older fuel tank and a new hose and quick release fittings to fit the motor. The problems is that the fuel pump isn't drawing enough fuel to keep the motor running. I installed a fuel pump kit last year and it didn't help. While I used the motor last year, I hooked up an electric fuel pump so that I could go fishing and it worked fine with the exception of a few drops of gas coming from the connection at the motor. This year, I bought a new fuel pump and installed it. It still doesn't seem to be pumping fuel the way it should, any thoughts?
