I have a 1988 130hp Yamaha that is not pumping oil from the reserve tank. The main engine tank is still 50% full. While I am troubleshooting this I just want to make sure that if I start the engine the oil from the main tank will be fed into the engine. From what I can see it looks like it gets fed from the main tank to a mechanical pump which feeds each cylinder. I just don't want to do any damage while troubleshooting. Also, does the main tank only get fed from the reserve when the engine is running? Any help would be appreciated.
