bone-a-fide
- Oct 15, 2008
- 11
Having issues with my oil flow alarm. 1987 Suzuki DT115.
In the past I have had issues with it going off that was RPM related. I have found this to be usually a bit of a clog on the screen of the sensor. Easy fix, clean it up, problem gone.
Last time this happened, I went ahead and replaced the sensor. Ran fine for a few outings. Last time out, the oil flow alarm started going off at a low RPM. It was intermittently going off, sometimes RPM-related, and sometimes just at idle. I believe the engine was getting oil, as it is smoking a bit as usual and more when it has sit for a few minutes and restarted.
What should I do? Replace the sensor again? I have never done any maintenance on the oil injection system. What is recommended if any here?
