speckhunter
- Apr 9, 2010
- 15
hay good folks, i own a 89 dt30c, "suzuki" this motor has been sitting in storage for three years. orinally i had a cooling problem. thanks for your help with that. it was the thermostat. now i have little or no throttle responce from idle. once i have the motor up in rpm all seems to be working fine but the hole shot leaves a lot to be desired.
do i need to run this motor for a wile befor i start to panic?
could the ignition timing switch part # 37920-95500 have anything to do with it, i have no idea how to use it. any help or sugestions? west
