Hey all,
I've recently purchased a Crestliner boat mainly for fishing so I will be using an electric trolling motor with a Deep Cycle battery.
Now, the engine on the boat is a Outboard 2004 Suzuki DF140 4 stroke and it's charging the crank battery but not the Trolling battery.
I was thinking of simply adding a battery isolator to charge both batteries but I'm unsure if this is a suported way of operating. Is it too much to ask from this engine?
If it is the way to go, do any of you have suggestion on which isolator to purchase and maybe a wiring diagram.
If it is not the proper way of doing I'm totally opened to other suggestions...
Thanks,
PS: Should the radio be mounted on the trolling battery?
PS2: Sorry if my writting is bad, english is not my primary language.
Thanks,
