From the top of mye internal oil tank i have a set of wires coming out with the colors red, black, brown and white.
The red wire has Y connected to it which is not connected to anything. Is this supposed to be hot? Should it be connected to + battery? What is it for?
You can see the wires in the attached image. The Y connection on the red wire is right under the starter motor.
