fishinberg
- Apr 14, 2010
- 7
I have a 2002 Yamaha Vmax 200 OX66 EFI with a couple hiccups. First off I have checked and have good compression and spark.
Problem 1:
I had an intermittent issue with the VST pump not turning on when I turn the ignition on. This happened twice to me last week, both times right after my buddy hooked up to tow me it fired. Since then I've run it without a problem for 5 days straight with no issue. I put my multimeter in the boat to check voltages the next time it happens.
Problem 2:
My engine seems to idle really rough and cough and sputter when I'm idling. Sometimes to the point it dies. I think it's fuel or fuel system related as I've heard nothing good about the ethanol. Last fall I replaced all the low pressure pumps and installed a new main fuel filter (boat side), but this spring it won't idle good at all.
Could you give me a list of things to check/clean and possibly how to do it. I don't own the service manual, but might look at purchasing one if they aren't too spendy and you know where to get one.
Problem 1:
Problem 2:
