inquisitive
- Apr 14, 2010
- 3
G/day
Neighbor ploughed into a mud flat doing 20 plus Knots, motor stalled and large puff of oily smoke was emitted. Since the incident oil is appearing in the motor cowl pan in sufficient quantity that when the motor is raised oil is being deposited onto the aft transom deck.
Tomorrow i will degrease the motor and run it in an attempt to isolate where the oil is leaking from. Enquiring whether anyone has suffered a like fate and can assist in determining where the diagnostic process should begin.
No oil is leaking from the lower leg, sump oil is not water contaminated, motor appears to function OK.
Appreciate if anyone can assist an old fella Aussie, thanks in advance.
inquisitive
inquisitive
