hi all, i have a dt65 on a 1990 and my bottom carb keeps overflowing up through the main jet from the float chamber? i have had it apart numerous times, the float when pushed up by hand works fine and shuts the fuel off, when i turn it upside down the fuel shuts off fine but as soon as i re-assemble it leaks through again. i have changed the float and the needle valve from another carb that works fine but again as soon as i re-build i have the same prob, when its apart and i put fuel pressure in there and hold the float up it stops the fuel fine, but re-build and the prob returns, if i shake the carb i can hear the float moving about so i know it isnt wedged or anything, there is no hole in the float or hairline cracks in the carb i am lost does anyone have any ideas????
thanks
thanks
