Carb cleaning Yamaha 50 2000 yr
JYESTREBSKY
Good Morning All,
New to site and to Yamaha O/B's.
Acquired a 50 hp Yamaha 2 stroke. 2000 model year. Sat for 2-3 years idle with gas in bowl. Varnished up inside. Ran 1 can Seafoam/ 1 gal 1:50 mix to help remove varnish but still seems to miss when going from low to high speed throttle up.
Question is: How easy is it to remove the carb's and clean myself? What is the best solution to clean with. I'm quite handy mechanically speaking.
Trying to help a friend get this motor back in working order.
Any ideas would be helpful.
Jerry Y.
robert graham
Re: Carb cleaning Yamaha 50 2000 yr
Berryman's B-12 is good, several other spray carb cleaners on the market, clean out jets with fine wire, air hose, new gaskets, O-Rings. Good Luck!
