Re: Suzuki DT100 oil injection bypass
does the engine smoke when running? are sparks wet with oil? if not then you have an oil leak, not an injection problem as the oil isn't mixed at the carbs. the oil is sprayed in to air fuel mixture after the carbs, this is right out of suzuki manual. you have another problem
