yamaha steering problem
lmdickens
boat has hydrolic sterring it will not turn to the left verry good fluid is full just had seals put in and its not better at all thanks
BaileysBoat
Re: yamaha steering problem
Get yourself a helm fill kit and Seastar oil.
http://www.iboats.com/Seastar-reg-H...51880194--**********.690306510--view_id.40306.
Or find the correct funnel. Don't let the fluid in the helm get too low while you bleed. Get yourself a helper. You have to purge the air out of the system.
This is for BayStar;
http://ww2.seastarsteering.com/PDFs/764600-H_10-12.pdf
Here is SeaStar
http://ww2.seastarsteering.com/PDFs/296784-AB_47-51.pdf
Take your time, it's not too hard.
lmdickens
thank you for the info and the links .does not look too bad to do
