I hope someone can clear this up for me. After winter storage, today I fired up my engine- runs fine- was peeing fine. Then I dropped it into gear both forward and reverse, then back to neutral. Then I noticed water leaking from my cowling into the boat well. I shut it down, pulled the cowling and searched for the source of water and was unable to find it. Then, when I started the engine again there was no pee trail. I can understand my impeller likely went bad especially since it has never been changed (my bad- I know). The mystery is, why would water come from inside the cowling as a result of a bad impeller? I would love to hear from anyone with ideas about this, as I am clueless.
Thank you
Louie...
Thank you
Louie...
