G
Guest
Guest
My 50 HP 4-stroke makes a noise when shifting into forward and into reverse. It is a"clank" type noise, not the gear grinding noise. The prop has some rotational play and the noise can be slightly heard when I turn the prop back and forth by hand. Is this noise normal? How much play should there be in the prop when I turn it back and forth?
