While working on the lower unit I would like to clean up / fix up a few things that are concerning me.
Primary on the list of concerns is the steering arm.
I know the powerhead must be removed, and I know the 6 midsection to powerhead bolts are the worst. I have managed to remove 5 out of 6, broke one, but will use the "drill through" trick documented on the forums here to get that last one out. So removal of the powerhead seems like it will not be a problem.
What are the next steps involved in swapping the steering arm? And what years are comparable? I have found a mid 90's complete transom mount for a 25" shaft (mine is a 20" shaft), and was thinking of just using the steering arm off of it. If this feasible? I just want to know compatability between 80's and 90's stuff for that one part
Does anything need to be pressed on or off?
