bamareed25
- Feb 16, 2010
- 4
When i try to crank the starter jumps up engages the flywheel but does not turn the flywheel. I tested the battery it read 12.6V with nothing on. With the Starter engaged it reads 9.6V. the power reads the same to the solenoid, however when i test at the starter terminals it measures 5.5V with starter engaged...is that a normal power loss? I checked/Cleaned all cables and conncections. I even bypassed the solenoid with jumper cables directly to the starter terminal with the same result...jumps up and does not turn the flywheel. I had it out two weeks ago and ran fine. Im at a loss for ideas. I am a novice at outboard mechanics. Also did have the batt tested at store....they said it was good. I have not tried turning the flywheel by hand, i dont know if that is ok to do and if i should remove plugs prior to doing so. Any advice would be greatly appreciated.
Thanks
Thanks
