transcat18
- Oct 30, 2009
- 2
need help! i have a suzuki df140 i have change the the thermostat, the impeller, and checked the pressure relief valve. it overheats at idle. at idle it pees weak, but at full throttle it has hight water pressure. I'm not getting any water out of the exhaust so I guess the the head gasket is fine also there is no water in the oil. can anybody guide me to the right place
it had started before i made all the changes. and i did not change the water pump housing. the housing is stainless steal and i had inspected the part look good but i did change the gasket.
