Thank you in advance for any good info....
Motor 05 Yamaha 60HP 2 stroke mounted on 05 Palm Beach 151 boat.
When not stuck, the steering operates smooth and free. However when I don't use the boat for a month or so, the steering is stuck. I have lubed the "grease/lubrication points" on the motor arm several times, but no help. When she sits a while, it's stuck again.
I am thinking about taking the other end apart (at the steering wheel) and try to send some lubrication in that end, but its up in a tight place, up in the center console, and I could use some suggestions how to do it, what to watch for etc...if you think that it may solve the problem.
Again, thanks for help.
