Hi,
I have a new DF115. The motor only has about 20hrs on it. I imported the motor into Australia from the USA with a new boat. For warranty work they say I must send the motor back to the USA - so for now that's not an option I'm going to consider.
At revs up to 4000rpm it runs perfect. at revs over 4000rpm after about 5 - 10min it starts to lose revs. The revs drop to about 2000rpm then back to about 4500rpm in a second and it keeps doing that until I pull back on the throttle. So far I've tested the petrol tank breather, changed the water separator filter and the local dealer change the internal motor fuel piping with a better quality stuff.
Has any one had a similar problem and what do you suggest I try next.
Thanks
DF
Thanks
DF
