Re: 1986,200 hp suzuki no fire at all
Turn2, I am not that familiar your motor, but your request needs a little help.
It sounds like you have replaced nearly every electrical component that you could get your hands on. Sorry to hear you did all that...:redface:
What was happening before you lost fire? Or is this a motor you are trying to revive? How do you know it has no spark, did you use a spark tester, or other method to verify no fire?
BIG QUESTION, is the kill switch plugged in? If you replaced everything electrical under the cowling with good parts, and no success, then I would find a wiring diagram for your motor, and dive in. Additionally, I would check any other safety features that would cut off the ignition.
