t marshall
- Dec 25, 2009
- 3
hi everyone. my 89 suzuki dt 55 wont keep an idle. it does out of the water when flushing for about 30 seconds then dies. In the water it does the same but alot faster to die. i have checked the compression thats fine (about 125 psi) installed new plugs and done a spark test that was fine. Fuel pick up in tank is good primer bulb stays solid. what should i be looking at repairing?.
