JimS123
- Jul 27, 2007
- 7,993
The motor is a 2007 model. I also own Evinrudes that are 1988 as far back as 1953 and all start 2nd pull. I asked this question 2 years ago but didn't really get a good answer.
The motor takes 8 or 9 pulls to start. I asked my local Yami dealer mechanic and he said check the choke. I pulled off the plastic cover and found that the choke on the bottom carb was open maybe 1/64". Not adjustable so I bent the linkage. Now both butterflies close tight.
The next time out it started on the 3rd pull. A week later I went on vacation and left the boat in the water for a week and it started first pull every time. Then I came home and a week later it took 6 pulls. Now its back to 9 pulls each time.
The carb is left full with the hose connected all the time. I use stabil with each tank. I pump the bulb (its always hard), turn throttle to "start", choke on and pull, pull pull.
I tried to replace this POS with an Etec this year, but the 25 still has not been released.
If this is normal for Yami, I'd just like to know. Once it is running it runs absolutely perfect all day long and starts on the first pull. Its just the cold starts that are a problem.
