Re: Yamaha 2005 V6 150 2 stroke
Install fuel/water separator(Walmart $27), use Stabil Marine and Ringfree all the time, drain carbs at least a couple of times per year with brass drain screw on bottom/side of each carb. Check and clean under cowl filter screen regularly. That should take care of your dirty carb problem. My motor is a 1999 90HP carbed 2 stroke premix and carbs have never been touched and motor runs as new, so I know this works. Good Luck!
