rcdatadude
- Nov 29, 2009
- 26
I have a 1990 Yamaha ProV 150. I'm having trouble with the remote oil tank pumping oil into the engine mounted tank. I'm working on trying to figure out what that issue is. I have one other question. I've noticed posts on the forum by Rodbolt that say.
"NEVER remove the engine tank screen/switch assy without first DRAINING the engine tank and ALWAYS retrieve and replace the screen to tank seal.
failure to follow this can lead to catastrophic engine failure."
In the manuals I have for reference, at the top of the engine tank, there is a removable cylindrical device the manual calls a Main Oil Level sensor. It appears to have a screen in it and a couple of vent holes toward the top. It also has a couple of triangles. One on the tank and the other on the sensor for alignment. I can't take it completely out since the wiring harness is short, but I have pulled it out as far as I could. Have I done something wrong? I didn't drain the oil from the tank before I did this, and I have done it 1/2 a dozen times. If I did do something wrong, what do I need to do to make sure the engine isn't damaged next time I use it? I am a newbie.... Any advice would be greatly appreciated. Thanks!
