I recently bought a project boat that has a suziki motor. It has a panel with three spots including a keyless switch that has 7 wires to it. The switch will not turn. I think I need a new one.There is also a push button that has up and down labeled on either side. This switch is wired to the ignition switch. In the middle there is an empty small hole as if something is missing possibly a kill switch? Is any body famillar with this system and what the function of each switch is. Where can replacement parts be found?
