Hi all,
I have just bought a 30 DMH Yamaha, and am in the process of ironing out a few bugs in it.
Have put a new water pump kit in, new plugs and t-stat as well.
I am stumped with a knocking that is in the engine. On the muffs, it seems to only knock as the revs are coming down, rather than going up. It seemed to do it more often if I reduced the revs suddenly.
The knocking is very hard to describe in words . . .but it seems like the driveshaft is trying to engage itself back into an already turning spline. It's hard to say if the noise is coming from the powerhead, or the lower unit.
I took it for a test run today, and found that the knock is worse under load. Whenever I tried to go more than say 1500rpm, the knock was there, and the motor even stalled a couple of times as the knock was happening.
Any suggestions as to where I should start ? I have a manual and average mechanical skills ( mostly learnt from iboats ! )
All help gladly appreciated. Thanks . . .
