Replacing plug wires Suzuki DT40
Firebored
My oil injection bottle is missing. I was told to mix 40:1, is this alright? I also have a "chewed" up plug wire, because the cover latch pin rubs the wire when removing the cover. Does anyone know if I can replace the wire seperately? The plug wire looks expoxy'd to the coil. Does the wire just screw on and off like a mercury outboard? can I use a plug wire from a 30hp Merc? Spark is arcing inside the cover from this wire. It's a 1992 2-stroke model.
