Peter Rogers
- Oct 12, 2009
- 2
I purchased a boat with a 1993 200 HP Yamaha engine a year ago. It is located on the Gulf in Florida and I the engine goes unused for extended periods of time (months). Each time I return the steering arm gets frozen up in the shaft on the front of the engine. I've been told to crank and lock the steering wheel so the rod is set all the way in the shaft so it is not exposed to salt and corrosion.
It still locks up and I have to spend considerable time freeing up the arm each time. Does anyone have a solution to prevent the steering arm from freezing up while I'm gone for several months? Thanks.
