I was running at about 4000rpms and the motor powered down and quit on me. After inspecting motor I realized the oil injection system was not working.I now am mixing the oil myself but the motor won't rev past 4200rpms. This motor has the oil flow sensor and the oil level sensor. Do I have to do something with these sensors for the electronic fuel injection to work properly? What would be the proper way to sucessfully disconnect the oil injection system? ie:leave the sensors connected or disconnect and jump the wires together or disconect completely. Currently I have the oil supply hose disconnected and pluged with oil in the oil tank so the level sensor think there is oil present. Also I have the oil flow sensor connected.Thanks for your help.
