I have a 2003 Yamaha F-225. I hit bottom a couple of months ago and since then when I raise or lower the motor the power trim/tilt motor bogs down and stops. If I let it sit a few seconds I can get it to go all the way up or down but it seems to be getting worse. The fluid tank is full and very clean. Is the motor going bad? There are no leaks and everything is very clean. The limit switch is sticking so I lubed it up and it moves more freely but doesn't spring back like it should. Thanks for any help!
Rob
Rob
