Re: Loss of power 1999 Suzuki DT 140 EFI
Try this. If you changed the fuel filter, and the fuel strainer cup screen on the side of the motor, and are sure the electric fuel pump is on....take off the fuel and oil supply lines line going to/from the fuel vapor separator (FVS), the carb bowl looking thing in front of the motor. two bolts will remove the FVS. Inside the line that goes from the diaphram pump to the FVS, there is a small cone shaped filter that sits inside the nipple that that hose connects on to. many times there is buildup in that filter and it will restrict the fuel flow going into the FVS. take off the bowl and check the needle valve that sits on top of the float, like a carborator bowl. look inside to be sure it is clear. Many times the fuel diaphram breaks apart or the fuel lines deteriorates (with the new gas) and small pieces of plastic/rubber lodge into the cone filter or into the needle valve. this stops the flow of fuel into the fuel/oil mixing bowl or out to the electric fuel pump. I found a small piece of plastic in mine. Dang Gremlins......
There are two sides of fuel for this motor. There is the low pressure side to the FVS and then the high pressure to the the injectors. the low side is volume, the high side is pressure. you do not have volume, if you run out of fuel.
I have a flow scan on my boat and at 2000 rpms you are using about 3gph, at 3000 rpms it is 5gph, at 4000 it jumps to 8gph and WOT its like 12gph. 2.5 MPG.
http://store.brownspoint.com/dt140/fig014-1408601.asp for a schematic.
there are also filter screens on the fuel injectors, but its not likely to be those.
