There is increasing chatter on other boards about using 2 micron racor fuel filters instead of the Yamaha specified 10 micron filter to help combat VST problems.
as long as it can flow a minimum of 60 GPH try it. it will cause fuel pumps to fail faster so more maint will need to be done and if it clogs it will run the VST out of fuel just like the yamaha 90GPH 10 micron.just remember thats 60GPH that day not the day its installed.
Does anyone have a part number for the racor 2 micron element with clear bowl? I currently use a 10 micron racor S3227 on a 320R-RAC-01 housing. Any ideas if I could use the same housing and bowl for the spin on 2 micon element? Thanks.
I have installed the 2 micron racor with a vacuum gauge between the filter and the VST. It has been running well for two months. Hopefully it will clear up the clogged vst filters I have had two times each summer for the past 3 years, not to mention blown power head and burned out fuel pump.
There is a compelling theory posted on another board that the famous white powder clogging vst filters (sodium sulfate) is caused not by a problem in the main fuel tank, but by heat in the vst tank creating phase separation. If that is the case the 2 micron won't work. I'll report back.
btw. the flow rate for the 2 and 10 micron racors is rated the same. I have tested it and both filters run at a vacuum of approximately 25 inches of water. The 2-micron will clog faster, hence the gauge to keep an eye on it.
